Discuss Inspection chamber inlet connection in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
tryhard
I have exposed the inlet on base of a 450mm IC for my future connection, offering up the underground swp to inlet appears to be very loose.
I have spoken to drainage suppliers who say the inlet socket should be a tight fit & demonstrated this with an chamber base & pipe.
The inlet seems to be 5mm to 10mm larger than my swp, impossible for a water tight seal against the existing rubber seal.
I have read somewhere a the use of a taper pipe, is this called a level invert taper pipe?.
Is this the correct way to go bearing in mind the LBC will be viewing this.
Any help would be highly appreciated.
Thanks Guys
Reply to Inspection chamber inlet connection in the Plumbing Jobs | The Job-board area at PlumbersForums.net
