Discuss Install Ditigital shower to avoid turbulence in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Hienekinuk
    Hienekinuk New Member
    I intend installing a Aqualisa digital shower. The mixing valves would be mounted in the loft. Water feed- Hot 22.mm copper pipe, Cold 15mm. copper pipe.
    I understand that turbulence can be a problem if the mixer valve is close to my last elbow. What length of a straight run would I need to avoid turbulence. My water pressure is 5 bar. Flow 15l./min. Combi boiler
    Has any one had any problems with Aqualisa shower installation and turbulence, or similar.
    Any advice gratefully accepted. Thank you.
    Heinekinuk.
Loading...
Similar Threads - Install Ditigital shower Forum Date
Landlords poor boiler install Gas Safe Registered Plumbers Only Yesterday at 6:06 AM
Can I install a Thermostatic Shower? Bathrooms, Showers and Wetrooms Wednesday at 7:56 AM
