Discuss installing drinking water fountain, double check valve? in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. Mgrant
    Mgrant Member
    I have a drinking water fountain to fit, Is a double check valve needed on the supply? Also are they usually piped up in the small bore plastic I have seen them fit with before presuming this comes with it?
  2. ShaunCorbs
    depends on type im guessing its internally?
    something like this?
    [​IMG]
    or is it like the bottle type?
  3. Mgrant
    Mgrant Member
    yes its something like the picture you have posted
  4. ShaunCorbs
    normally hard pipe (15mm) and no check valve is needed but always good to fit a double
  5. Mgrant
    Mgrant Member
    thank you. the double check valve advisable. Encase someones mouth touches the spout?
  6. ShaunCorbs
    excatly or someone tries to fill a cup up on it
  7. Daniel Hall
    Daniel Hall Member
    I've just finished a spa/gym/swimming pool place and I've got them on all water fountains. Stops the jobs worth m+e consultants picking anything uo
  8. Mgrant
    Mgrant Member
    Its like the one in the picture, what kind of height would you generally set these at off the floor?
  9. ShaunCorbs
    What age ?
    And normally ask / look around the school if there's any others
  10. Mgrant
    Mgrant Member
    Thanks its not a school a workshop so all adults
  11. ShaunCorbs
    Couple of options basin height or 1m or what ever height there happy with
  12. Mgrant
    Mgrant Member
    Thank you so basin height 820 or higher around 1meter. So people don't have to bend down as much to drink from I guess
  13. ShaunCorbs
    Yes spot on
  14. Mgrant
    Mgrant Member
    Thanks I'll likely go at around 1meter
    • Like Like x 1
  15. Chuck
    Chuck Active Member
    Be careful about guessing this one. You need to consider the need to make such facilities 'Accessible' to wheelchair users, etc. these days. I don't know all the rules I'm afraid but better to check before you install.
  16. ShaunCorbs
    Normally fit a second at kid height too low of adults to use
  17. Mgrant
    Mgrant Member
    Thanks maybe a daft question what kind of angle do you position the tap at to the the spray right same as the picture I'm guessing
  18. Mgrant
    Mgrant Member
    Just looked on the webpage for a similar fountain there recommending 915mm to front lip for adult height
  19. ShaunCorbs
    its about right
  20. ShaunCorbs
    CAESAR32 ??????
Loading...
Similar Threads - installing drinking water Forum Date
installing a new sink unit with a new tap position Plumbing Forum Dec 23, 2017
Installing Mermaid laminate panels Bathrooms, Showers and Wetrooms Nov 5, 2017
