Discuss Intergas intouch installer app in the Plumbing Jobs | The Job-board area at PlumbersForums.net
king of pipes
Subscribed
Anyone downloaded this app and registerd on It asks you to enter coc number any ideas what that is ? Any advice welcomed cheers kop
Anyone downloaded this app and registered on It asks you to enter coc number any ideas what that is ? Any advice welcomed cheers kop
Yes have downloaded & used it for 3 boilers, (Mi reg) seems to work fine & saves the registration cost too. Don't remember coc number though, but your local rep will authorise the access after you access the app from https://www.myintergasregistration.co.uk/app/register after this you should receive a message "
Your local Intergas Sales Manager will contact you within three working days to progress your registration.
As part of the registration process you will need to provide an image of your businesses Gas Safe Register “Registration Certificate” (not an image of a Licence Card). This is a requirement by Gas Safe Register, if you have this ready for when your manager calls it will speed up the registration process"
When you use the Mireg app there is a bit of an anomaly in that If you have a heat only boiler you will need to put something in the boxes for hot water - even a dot will do- as it will not allow you to register the product unless there is an entry of some sort in the relevant section.
Regards
Arthur.
Thanks Arthur i know about the MIapp bud , i was refering to the installer and service app which allows the installer to access the customers boilers which you have installed i have found out its not a necessity to fill in the coc number when you register , i presume coc number is certificate of compliance but not sure ? Regards kop
Have not used that as yet but it seems very clever in that it will send you a message telling you of the fault possibly before the owner knows its gone wrong.
Regards
Arthur.
Reply to Intergas intouch installer app in the Plumbing Jobs | The Job-board area at PlumbersForums.net
