Discuss Intermittent hot water with a Baxi Platinum 33HE in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dingdong
Hey guys,
The boiler is only firing every 20 secs for about 20 secs for hot water. Continuously cycles like this.
Trying to gauge if this is a problem for a pro or a DIY thing to fix. Any ideas?
Cheers.
Sorry to say gas safe engy needed
Reply to Intermittent hot water with a Baxi Platinum 33HE in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, just moved a radiator from one wall to another, straight forward job, heating is working, problem is that on turning on a hot water tap the water coming out is heating water ( Fernox smell)and the boiler pressure drops quite quickly. Baxi Platinum 28HE. Any help or ideas please
Hello All, I wonder if you can help me? I have intermittent hot water low flow from all taps in my 4 bedroom house upstairs and downstairs. I can sometimes recover the usual water pressure by turning the hot and cold water taps on and off which seems very strange to me. There is no problem...
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that heats on controlled load over night. The large tank is in roof space of 60s built villa unit. Every few mornings, no hot water will come out of...
Evening All, Been having on and off issues with a Greenstar CDI classic Combi were the hot water is not heating up but only intermittently. Some days/ weeks it’s fine and works fine all of the time but on the odd occasion it’s been running cold in the following sequence. It fires up the boiler...
Hello there, Baxi boilers (with HAGC03 BX01 motherboard) have a parameter, named "Ignition delay (for HO)". It is the Parameter 74. My question is that what mean it exactly? I search a parameter that same like vaillant"Max. anti-cycl. time: Heating" mean:
