Discuss Is there a Direct Open Vented Combi Boiler available on the market? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Issue is – We have a Mains Pressure Hot Water, Open vented, Solar thermal storage unit in a single storey property with 2 <u>Direct</u> feeds (One for multi fuel burner and one for oil/gas boiler). There will be a boiler stove fitted to one and it’s planned to fit a gas boiler to the other (in kitchen) as backup. BUT, the hot water run back to the kitchen from the cylinder is around 20 meters which will have a big delay to the hot water.&nbsp;<br><br>Is there a DIRECT Open Vented Combi boiler that will support the cylinder with CH supply but hot water to the kitchen? All the ones I can find are sealed systems!
Not sure if you can or would want to add a secondary hot water circuit to a thermal store, in your case I'd just install a small water heater (gas or electric).
I would not go down the route of a combi boiler here. Is it not possible to add a plate heat exchanger off the thermal store to provide hot water? That is providing there are spare tappins near the top of the store. It may be worth taking to the thermal store manufacturer.
Reply to Is there a Direct Open Vented Combi Boiler available on the market? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Background 24 apartments are equipped with thermal stores of (100 to 150 litres) with immersion heater capability. Individual demand of each apartment for domestic hot water varies greatly in timing and volume. Thus the oil boiler is required to work for long periods which is uneconomical...
My Grant combi oil boiler is giving me quite a headache at the moment. When I returned home last Friday I'd no heating or hot water. An engineer called the next day and diagnosed a faulty pressure switch. This was changed and everything seemed ok. However then the boiler began to lose pressure...
Hi, I have a hot water cylinder which feeds 3 outlets (kitchen sink, basin in bathroom & bathtap) which has never had very good pressure (probably because of the set-up) but last year got so feeble that a guy suggested fitting a pump alongside the cylinder. This can work fine but then all of a...
1K
PLUMBING ADVICE NEEDED Combi boiler in our house, downstairs water seems to be piping hot. Upstairs basin, bath and shower only ever seems to be lukewarm - so much so that no one even wants to bath as it never gets hot enough! Open to suggestions as to what it might be and if anyone can...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new well maintained Worcester combi boiler. We weren’t convinced the heating was working right and then got hit with a £610 energy bill for the first 6...
MartinPod81
M
