Discuss JAQUAR cartridge help in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
Tags:
  1. Ben Speller
    Ben Speller New Member
    good afternoon lads and lasses
    i've replaced the cartridge on a Jaquar shower diverter because it was constantly dripping.
    it stopped for a few days but has started again
    i only replaced the central part because i can't for the life of me work out how to remove the outer part (pictured)
    jaquar are an indian company so i'm struggling to get any telephone technical help
    i cant get it to pull out or turn and its not threaded!!
    any help greatly appreciated and thanks in advance
  2. jtsplumbing
    jtsplumbing Plumber GSR Top Contributor!!
    What do you mean by the outer part, ? do you mean the part with the thermostatic cartridge ? if you mean the part your holding it Proberly pulls out But it could be jammed maybe some heat from a blow torch could help
    • Like Like x 1
  3. Ben Speller
    Thanks for the response jts
    Yes its the part that I’m holding.
    I thought the top cartridge was just a diverter with the thermostatic control below.
    I’ll try and heat it up a bit.
    Thanks.
Loading...
Similar Threads - JAQUAR cartridge help Forum Date
Dripping tap ceramic disk cartridge. Plumbing Forum Feb 2, 2018
Difference between ceramic cartridge and check valve taps Plumbing Forum Jan 2, 2018
