Discuss Just saved a cat stuck up a tree in the Plumbing Jobs | The Job-board area at PlumbersForums.net
gas tec
I had a combi change on today with a small gas run and change all the radiator valves upstairs...a big job for a Saturday.
On my way home I then called in to my in laws to rescue their cat. It had been stuck up the tree for about a day, bloody high up the tree as well.
I get roped into all sorts of jobs, I'm knackered.
Im straight on the drink tonight, What a day!
Awww a hero!! Was the cat OK?
The cat would have come down when it was hungry or thirsty.
Probably thought it was going on some 'feral' adventure due to instincts.
Be prepared to fetch it out of the tree some time in the near future!!!!
Yes the cat was ok, I said just leave it until it comes down. I can't be bothered to go and save it every time.
I have 3 cats myself so I had to go up and get it.
Aw Dan saved ours at the weekend too. He got himself stuck and couldn't remember how he got there so Dan went up the ladders to get him.
Reply to Just saved a cat stuck up a tree in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
So my toilet got blocked and none of the usual methods were working. I had a drain snake lying around in a kitchen drawer so thought I'd give it a go. I didn't bother to check online how to use it etc (obviously 🙄) I just shoved it down the u bend and wiggled it about a bit and all the Rubbish...
I am seriously stuck with an underfloor heating system which isn’t getting warm enough. I have previously had it working perfect in January however is been off a year and now decided no to play ball. I have changed the reliance thurmogaurd mixer which has helped and the manifold is now getting...
2K
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The existing pump flows downwards. The manual for the proposed replacement recommends that it should pump upwards. This would involve rearranging the flow &...
Hi all, My push up plug in the bathroom sink is stuck. Please can you let me know if you are able to fix it and how much it will cost? I am in the Purley (near East Croydon) area. thanks, Nav
56K
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised valves simple bi-metal thermostat on wall in flat with 4 standard TRV's rarely used so not worried about the flat, and main house has Nest Gen 3 in the...
