Discuss Kalderwei / Trojan baths in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
Tags:
  1. Dbas
    Dbas New Member
    Hi all,
    I'm looking to replace my bath, and I was recommended a Kalderwei Eurowa bath. I read that Kalderwei baths are manufactured in Germany, and are supposedly good quality. I suspect Eurowa is probably bottom of their range as it isn't even listed on their website, but I was recommended that from the Victoria Plumbing website.
    My other thought was a Trojan bath. Victoria Plumbing has just one Trojan Bath - the Trojan Granada II acrylic bath.
    I mention these two just because they are on Victoria Plumbing's website... which I suppose my fitter gets a trade discount from.
    Any thoughts on either of these two brands, anyone?
    Thanks in advance.
  2. Phil
    Phil Plumber
    Trojan baths made in Huddersfield, Victorian plumbing do a trade discount? Where do I sign up?
    • Like Like x 1
  3. Dbas
    Dbas New Member
  4. townfanjon
    Just because it says trade log- in please dont assume we get it any cheaper, we dont. .
    I am also very supprised they are selling decent branded baths , both are good , but just check the acrylic thickness especially if its a shower bath .
  5. Dbas
    Dbas New Member
    Ah I see, thanks for helping to clarify @townfanjon@townfanjon. One of the fitters said he can get various trade discounts, I (mistakenly) assumed Victoria Plumbing would be included.
    What is the minimum thickness I should be looking for in acrylic baths? It is a shower bath I'm looking for.
    Thanks in advance
  6. ShaunCorbs
    If it's a stnd shape bath I would if you could go with a good quality steel bath
  7. muggles
    muggles Member
  8. johnf
    johnf Active Member
    Eurowa baths are good. They come in a couple of different thicknesses. They are steel, you can have grips, anti slip etc as add ons. We put a couple in last year and all customers happy. They are good value for money.
  9. CHRISX
    CHRISX Active Member
    Hello Dbas,
    I would recommend that You go for a `Supersteel` Bath and I recommend Bette baths which are manufactured in Germany.
    I have one of these Bette Supersteel baths in my own Home and they are FAR superior to a `normal` / inexpensive Steel bath - the steel is thicker and the enamelling is also of a superior quality on Bette baths.
    However - with Bathrooms almost invariably `you get what you pay for` - and Bette Supersteel baths are not `Cheap` - either in quality of manufacture or price.
    Here is a link to a Bette baths Supplier / one example which is heavily discounted at present - £287.00 off RRP:
    Bette SET Rectangular Super Steel Bath 1600 x 750mm - 3660 000 [Code No.]
    This is longer and larger than a standard sized Bath - the wider section to accommodate a Showering area - but note there are no Tap holes.
    There are a lot of Bette baths to choose from regarding Size and Shape if you search around.
    Chris
