Bruno lang
Hi who supplies the kamco cf40 or cf90 powerflush machine at de best price?! I will be getting it sent over here to ireland
Discuss Kamco powerflush in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Go for a MagnaCleanse, cheaper, no moving parts and much more impressive to show customer collected magnetite.
So you'd recommend the cf90 with the magnacleanse filter? Would you do many flushes a month? No1 doing powerflushing within a 40-50 mile radius so planning on starting after I do the course and do 1 or 2 of the families houses for practice!If it were me I'd have the 90. And the magnacleanse but I already own the magnawotsit. I have used the kamco magnet and my only grumble was the seal on it kept leaking but that was down to its age. In comparison I wouldn't say one collects any more or any less then the other, but the magnathingy is a double unit
Or better still, buy the Kamco direct from the manufacturer, and buy the Combimag unit which also impresses customers by catching the debris. And allows you to use an immersion heater fire when the boiler is dead.
magna clean is limited on its own. You still need a more powerful flush to shift the sludge and stuff.
Both together is overkill imlo. if the powerflush machine is any good then a magna clean attached to the power flush is really not needed, it looks good but showing customer the start and correct finish ph would do ?
the kamco filter is handy being transparent. I used mine today.
Nothing like a bit of suspense!
ive used the kamco mag and it does the job well and quite like peering in although I think the magnacleanse is better value.
Do you not find the cf40 creates a lot of bubbles and foam with the chemicals?
Reply to Kamco powerflush in the Plumbing Jobs | The Job-board area at PlumbersForums.net
