Discuss Kane 455 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
james the plumb
Hey guys.
Jus bought a new kane 455 cracking bit of kit but i cant turn it off, tried purging out side but still no joy!
any ideas??
Mine played up the other week. I called Kane, and then it sorted itself out while I was on the phone.
Check something. Mine had been in for calibration, and they'd put non rechargeable batteries in it. (Normally they put rechargable).
So I had been charging normal batteries. Think that may have accounted for the weird behaviour.
press on/off hopefully switch off after 30 secs, if readings dont drop back to zero after purging a couple of times you might have overcooked it but it will normally purge down and turn off, if not back to kane!
havent managed to destroy mine to date, and its popped off the scale a couple of times
dont have the analyser in the flue while the boiler fire up or shuts down, if the co reading is above 30ppm i think it will not shut down straight away. Read the instructions again, best pull out the probe and wait untill the readings go down then turn off.
Reply to Kane 455 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
  • Sticky
