Discuss Keeping a wasteflo lifting station clean in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
I have just cleaned out a Stuart Turner wasteflo lifting station which was clearing waste water from a basement. It has a washing machine, a kitchen sink and a dehumidifier empting into it and had become blocked. It took a while to clear of all the much which had built up over 2 years,
Stuart Turner recommend putting down anti-bacterial wash down the wasteflo every 6 months to keep it clean. However they do not recommend a particular type.
What would people recommend?
Paul
Take it that was a LS 5.
Hard water area then go to fleabay, put in Saniflo and just about every make of cleaner / descler will be there.
Reply to Keeping a wasteflo lifting station clean in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I've recently had a new bathroom installed. I've noticed when I flush the downstairs loo there was a hammer type noise under the bathroom floor when the cold feed for the loo turned off/ same with the washing machine. So I turned off the mains water supply. Opened the highest tap first...
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by the survey. I have had loads of plumbers over, and have always carefully checked their reviews/tried to vet them as much as possible. However, I've had...
Hi there, So I have thrown several methods of drain cleaning from each side of the sink which has improved the issue but it still persists. When draining larger amounts of water from the kitchen sink, or when the washing machine drains out, water starts backing up and coming out at point one...
1K
Recently over the past 2 months, the boiler or area by the water tank has started making a loud groaning noise whenever hot water has been running for much over a minute (sometimes less). Since the weather has gotten cooler, the radiators seem to come on (unless turned off at the TRV) whenever a...
2K
Hi I need to connect a kitchen sink to a soil stack but the soil stack has an inspection hatch and what looks like a reducer into a clay pipe into the floor making it very difficult to fit a boss. This should be pretty straightforward with a boss, but the level where the boss needs to fit is...
3K
