Discuss Kingspan rainwater system - water constantly running in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Centralheatking
Neighbour in Cornwall has such a system but is suffering constant 'water running' sound
whilst the panel shows 'power' and 'status' ok - the pressure is low.
I suspect a leak on the feed to point of use, or should I advise a pressure re-set.
Suppose 1st point of call would be turn off mains over-ride supply and see if noise stops
Any Ideas much appreciated Centralheatking :81:
Going out till 3 pm - work back via Kings Arms !
Rainwater Ball / fill or solenoid valve may have grit in and tank overflowing.
If it's got filter backwash, backwash solenoid may be open.
Well done snowhead - I will advise my neighbour on Monday am of
all the possibles and as is only the decent thing to do report back on here
the results .......Centralheatking
Reply to Kingspan rainwater system - water constantly running in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
