Discuss Kitchen Sink Gurgling in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We moved into a 1st floor flat, about six months ago, in which the sink gurgles about 3-4 times a day. Sometimes a sickening sulphur / egg smells joins the noise, to the extent that we want to leave the room. Sometimes it happens just after we've had the washing machine or sink running, but just as often we haven't used the water for a good few hours.
The block of flats is about eight years old and prior to is moving in, our flat was unoccupied for about 2-3 years. We have a double sink, the smaller side bit has an overflow. We rarely use the smaller side sink and until I ran water through the overflow today, I don't think water would have passed through it for several years. The dishwasher and washing machine also connect to the same set of pipes.
I've disconnected and cleaned two of the PVC pipes under the sink. I've attached a labelled photo of the set-up, and what I've done. (Apologies if anything I've labelled is obvious to the reader.)
1 - This wasn't blocked but was lined with a stinky black gunk, which I removed
2 this comes from the main sink. Gunk also removed
3 connects the side sink overflow. It's bound by adhesive to the side sink. Haven't removed it
4 Plug in side sink - haven't removed
5 washing machine
6 dishwasher
Since I reattached the pipes I've also sent bleach down, hoping to kill off bacteria and reduce the chance of smells. I'm also planning to send down baking soda / vinegar to clean them further.
Something googling threw up was replacing part 1 with an anti-vacuum equivalent. Is there any sense in that?
Any advice would be greatly appreciated, and I'm happy to post further photos if needed. Thanks.
1. The flexible hoses to the washing machine and dishwasher (your number 5 and 6) don't appear to rise to a level immediately below the work surface and then drop to their spigots above the trap. There is therefore likely to be water (stagnant?) trapped in these pipe. These could cause the gurgle and smell.
2. The white plastic pipe labelled 8 is most likely the condensate drain from the boiler. Some boilers discharge the condensate as a slug of water, rather than as a continuous trickle. This could cause the gurgle. It could also be "pulling" the water from the trap (your item 1) which would allow foul smells from the sewer back into sink. Its not very likely given that its a small pipe discharging into a larger one, unless the larger pipe is partly blocked.
3. There may be an issue with the drains beyond the point where the white drain pipe disappears through the back wall.
I'd suggest you first try re-routing the washing machine and dish washer waste pipes (grey, corrugated) so that they rise as high as possible before falling back to their spigots.
If either symptom remains, you need to investigate the drainage system beyond what is visible in the picture.
Cheers for the replies.
I was guessing that 8 was coming from the boiler, but couldn't be sure.
So essentially there are 3 scenarios.
1) the gurgling is being caused by our washing machine or dishwasher, and if so it's realistic to fit that.
If we didn't use either for 3-4 days, and the gurgling continued as before, would you rule that out? I'm trying to think of a way of working it out before I go to the trouble of cutting into the back of the cupboard to move the flexible waste pipes.
2) we have a blockage somewhere in our flat. And knowing that we don't have any drainage problems and I've taken most apart already, the blockage is below the water trap.
That I can tackle / eliminate by plunging etc
3) the blockage potentially lies with a neighbour or in a communal section of piping.
If there's glugging and a smell when you're not doing anything, that points to positive pressure in the drains pushing smells out.
Is there a vent pipe on the roof? If there's a partpartp blockage or the pipe is full of water and it's on a branch without a vent, you can get air forced through the traps into the room
Not the real answer, but worth putting in a tee with anti vac air admittance valve. Some building inspectors asking for them now. could be a nightmare to track down proper venting.
Reply to Kitchen Sink Gurgling in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Had the plumber replace the pipes less than 2 month from the sink that lead into a cast iron pipe. They also unblocked gunk from the start of the cast iron pipe. The gunk is in the photo I've attached. The pipe work is also attached(it's disconnected as we cleared the u bend to clear it out)...
Hi, We have noticed for a while now that when our washing machine nears the end of a cycle we get a bad smell of dirty water in the downstairs toilet which is next door. We have moved the washing machine as we are having floor tiles put down and have noticed that the waste pipe is full of dark...
My mother has been away on holiday for a few weeks and she has a kitchen mixer tap that has a very slow drip nothing significant - been like that for a couple of years. The mixer has a a long spout that can be rotated between sink and drain bowl. She left the house meticulously clean. I came to...
Hi everyone, I got the water tested in my flat which has high chlorine levels and I am going to get a under the sink filter chlorine remover fitted as I am sensitive to the chlorine levels. My question is that the filter will be fitted on the kitchen cold water pipe under the sink but the...
R
Hi, I've just purchased a portable washing machine and want to connect it to my kitchen tap. I know I'm going to need an adapter to connect it, but am struggling to work out if the aerator in the tap is removable. I can see 'Airforce' written on the side of the aerator and the aerator has...
