Discuss Lagging cutter. New invention in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. Chalked
    Chalked Plumber GSR
  2. turnpin
    turnpin Trusted Plumber
    Hi Chalked ...Will make a neat job I've seen some of your install pictures so will be the bees knees....how much out of curiosity if you don't mind me asking...regards Turnpin:)
  3. ShaunCorbs
    seen and already got one very good needs some mods tho
    • Like Like x 1
  4. Chalked
    Chalked Plumber GSR
    £17
    • Like Like x 1
  5. Matchless.plumb
    Matchless.plumb Trusted Plumber GSR
    Did you buy just the guide or saw and sharpener as well?
  6. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
  7. jtsplumbing
    jtsplumbing Plumber GSR
    What size does it take ? Think the clamping method needs looking at could take some time to make joints, Think I will wait for the Mk2 model !
    • Agree Agree x 1
  8. ShaunCorbs
    15x19mm all the way upto 28mm thick
  9. Harvest Fields
    It is actually ok. Watched it in person. Definitely would take a bit of practice to get used to though. The clamp doesn’t have to be tight. It is more about the blade being sharp so you get a clean cut. The clamp is just a guide to run the blade down
  10. scott_d
    scott_d Plumber GSR
    It looks good, hopefully as easy to use as the video.
    The guys on site just use a bread knife
  11. Riley
    Riley Plumber GSR
    Do us a review I’m intrigued I hate cutting lagging
    • Like Like x 1
    • Agree Agree x 1
  12. YorkshireDave
    YorkshireDave Plumber
    Bread knife lubricated with water! Remember, the grey (polyethelene) is easier to cut than the black (nitrile). Never zip tie as you seriously reduce effectiveness if its compressed. Clip or tape the grey, glue the black..
    • Useful Useful x 1
  13. Watts
    Watts GSR
    Leaves a very neat professional job I'm quite impressed. It comes with a toothless saw which will probably get lost in the van but it makes a brilliant looking cut.
  14. ShaunCorbs
    The saws an extra
  15. YorkshireDave
    £17 vs bread knife at £6 ;)
Loading...
Similar Threads - Lagging cutter invention Forum Date
Olive Cutter or puller Plumbing Forum Apr 23, 2018
THE NO.1 TOOL FOR CUTTING BOILER FLUES - FLUESHOE CUTTER Plumbing Forum Mar 23, 2018
