Discuss Landlords poor boiler install in the Plumbing Jobs | The Job-board area at PlumbersForums.net
king of pipes
Subscribed
Last call of the day and what a mess this boiler was installed a year ago only 3 radiators in the property years old piping should have been replaced in my opion so many installer faults i could not issue a certificate on this pile of garbage how many faults can you spot and how would you categorise it . cheers kop
You quoted to put it all right? Bet it wasn’t registered, Or notified.
Art is everywhere don’t you think :) would not believe it’s registered..
Furthermore I wouldn’t believe that any customer would be satisfied with a pile of ..... i mean it’s partly the fault of customer to give the, the permission all is fine ... you must be blind or have no understanding whatsoever. Definitely shocking
You made my morning :) almost dropped the bowl of porridge
no bud steering well clear of that one , warranty is void as not fitted to MI at least 10 faults on the install ,will cost to much to sort that one out prv into a condense pipe is a no no and they have used the old fortic cylinder over flow, to long a run even for the condense alone no fall and to small, why do they do it I feel a GASAFE INSPECTION coming . cheers kop
Good luck finding the installer
The annoying bit with it is when they are £50 cheaper but don't fit a few hundred pounds with of filters, lime fighters, chemicals etc etc
They are actually making more money than the guy doing it properly
We all will get the phone call afterwards to come along and put things right :) and even if you tell them what you have to do and what’s the cost they still go with someone cheaper :) they will never learn
On a serious note got to be at risk not spoken to the landlord but its going to make his weekend not and make me look like the bad guy but got to be done. Kop
Yes mate, talked to the landlord he was not a happy contacted the installer who turns out to be someone i have had to go behind before hes not got the balls to confront him just asked him to do the landlords . kop
Reply to Landlords poor boiler install in the Plumbing Jobs | The Job-board area at PlumbersForums.net
