Discuss Last night apprentice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Nope because I wasn’t and I wouldn’t have called it BOXT. As you are asking do s that mean that you did??
Nope. Absolutely nothing to do with it. But there are obviously enough idiots out there to provide a "nationwide" network. With what I wrote I don't see how you think I would have anything to do with it. Bit daft to even suggest.
It was a joke mate. :p:p
BOXT sounded good. A Baxi, Worcester-Bosch, or Vokera for around ÂŁ2500 installed. They even tried to suggest a combi even though I'm on a shared supply, but I declined. There is obviously no need for a site visit to test water pressure or discuss my needs - that is just an excuse to try to get free biscuits, isn't it?
Then I looked at one of the suggested boilers. Despite being heat only, it only supplies 10.2 litres of hot water per minute, as well as having a N/A hot water flow rate. It also comes with a low energy pump, a free system cleanse (whatever that means), and a free filter worth ÂŁ130. Must be a really good filter. And they can do it in a day.
I wonder if they know the Artex on my wall where the boiler is mounted has asbestos in it, or that they'd need to replace the entire gas run from the front of the house and can't lift the floor due to UFH?
No problem for them - the Terms and Conditions simply allow them to up the stated price when they get here and find that the job isn't so straightforward as it looked!
Boxt install rates arnt bad straight swap no extras eg new gas run etc
ÂŁ400 min
Trashy pointless business plans drawn up by spoon fed, ÂŁ5 a cup coffee drinking, entitled, 4pm finishing, worthless degree holding, non real world living, snowflake non job jobsworths!
We were thinking the same thing!!
I don't really want either of the finalists to win
Does it count if I finished at 2pm today?
Reply to Last night apprentice in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, My step daughter was ripped off by a cowboy builder so I’ve been helping her out and fittted her two radiator. I’ve no idea what is under some of the floors or in the walls but since flushing it all out and starting the combi up she’s been having problems with her heating. She reckons the...
Hi all. Not sure if it's a plumbers job or another trade but thought I'd ask. I am installing a new toilet downstairs next to an outside wall. There is a 3 way inspection/access chamber about 1.5 metres outside this point which I plan on going into. It has one inlet in use from the upstairs WC...
Hi guys. I've been running an UFH installation/ repair business for 7 years now and one of my main frustrations is finding the parts for the UFH. I've got quite good at it over the years being able to recognise the manifold brand and generation by just looking at it but then I have to go through...
Hey all, Looking for some advice. My mother recently had her boiler changed but in the process the water had to be turned on and off as you would expect and the engineer broke of the handle. Luckily it seems you can close the valve with some pliers on the but I don't believe this is best for...
My daughter bought her first home and was hoping to convert to gas but its not available in the area, so thinking a boiler upgrade is the better way to go. Just after some advice and rough costs involved, is it worth getting a pressurised system installed and a new boiler and oil pump? Heating...
