Discuss ldeal logic + 30kw combi in the Gas Safe Register Forum - Public Forum area at UKPlumbersForums.co.uk.
Tags:
  1. plumber_UK
    plumber_UK New Member
    ideal logic combi losing pressure daily. Initially i thought it was a leak on the system so all the pipework was checked and no leaks found
    The flow and return were isolated overnight with no demand and there was a pressure drop. I disconnected the condensate pipe and put a bucket under it but no leak.
    I did the check a second night but it didn't drop.
    i thought i must have missed something so i have isolated the flow and return again and the pressure has dropped within 30 minutes by around 0.5bar.
    Has anyone come across this before ?
    The boiler is under warranty but i dont want ideal to come out and say its nothing to do with the boiler.
  2. sammathias
    sammathias GSR
    Get ideal out. Tell them.you have isolated the system pipework and pressure has still dropped.
  3. townfanjon
    townfanjon Trusted Plumber GSR
    Put pressure up to about 2 bar and try it
  4. scott_d
    scott_d Plumber GSR
    Any drips from the PRV pipe outside?
  5. jtsplumbing
    jtsplumbing Plumber GSR
    Get them out on a warranty call, could have a pin hole in EX , but don't mess around with boiler if still under warranty
  6. plumber_UK
    Thanks. i'll get ideal out and see what they say.
Loading...
Similar Threads - ldeal logic 30kw Forum Date
Ideal Logic Combi 24 problem Gas Safe Register Forum - Public Forum May 30, 2018
