- Messages
- 24
To me it looks like the previous olive was quite a long way further up the pipe. Yet you say the pipe is fully home in the fitting? You definitely have 1/2" of pipe under the olive then? Don't try to solder wet pipe or if water is dripping down it - it won't work (although I did it with success today) but not a problem if using compression (or pushfit copper).
It felt as though it was home as it wouldn't push any further in to the joint. I did give it a good wipe when I took old one off but I can see what you mean. When I strip it I will see if it can go further in to the joint.
Thanks for the advice.
