Discuss Leaky tap. How does the cartridge come out?! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all,
Super novice question - but I how do get this cartridge out? The tap is leaking from the base (under the sink). I was going to see if replacing the o-rings does the trick but I can't seem to get the retainer nut thing out as there isn't a bolt on top of the tread like I've seen in every other tap and I don't want to force it.
Is it removed from the bottom when the whole tap comes off?
Thanks in advance!
Thin jawed adjustable in the gaps, then use another adjustable on that to unscrew it
Whats the tap make & what hot water system do you have? There's reason for the Qs.
Reply to Leaky tap. How does the cartridge come out?! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
