Discuss log burner and gas boiler into thermal store = persistent problem frustrating for me the homeowner in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Deleted member 96758
In 2012 we had a thermal store installed with a log burner and regular gas boiler feeding it. pretty much since then it hasn't worked properly, the original fitter has since retired and a couple of plumbers and an electrician have looked at it but cannot get it to work effectively.
The idea was that the log burner whilst not running the heating could at least contribute when lit during the day as I work from home, then the gas could top up when needed.
It seems from conversations over heard that they cannot decide on a wiring system J plan F plan ? means nothing to me.
I'm not looking for advice to pass on to a plumber, I'm looking for someone to come here and fix the problem for good. I'm fed up with paying plumbers for attempting. no win, no fee please.
The issue is: currently the HW can only be on if the CH is on also. the result, we rarely get hot showers in cold weather and then only when the house is up to temperature.
The setup is:
Worcester Bosch Greenstar Ri regular Boiler
Honeywell wireless room stat
Drayton Lifestyle LP722 programer
Newark 'Enerstore' Thermalstore (vented hot water Storage system 250l)
6kw log burner with dump radiator etc.
Reply to log burner and gas boiler into thermal store = persistent problem frustrating for me the homeowner in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm looking for help with an open vented central heating system that is pumping over. We have a thermal store that has two heat sources - gas central heating, and a wood burner - both feeds are pumped with a Wilo Smart A 25/4-130 circulation (one pump per feed). When the wood burner kicks in...
I'm looking for some advice on a frustrating problem I'm having with my old Eurostar 50-60s oil boiler please? Although it's old, most parts needed to operate it are now new. The symptoms indicated a broken/seized burner motor or oil pump. I wrongly assumed the motor so I ordered a new one only...
J
Hi all, I am a plumber but I do not carry out works to boilers as the majority of my is bathrooms so I am not gas safe. I have completed a bathroom for a regular customer. She is of old age and is starting to get a little clumsy and her son has asked me to look at the old gas fire/back...
Not sure what my options are here. Basically a friend of mine recommended his father in law to do our plumbing/gas work for our renovation. First job was to install a new boiler, and later install radiators, bathroom, kitchen, etc. The boiler was installed last September but not switched on as...
2K
Dear All New member here, coming looking for help. A few weeks ago I had work carried out by a British Gas Homecare service technician. It required a drain and refill of the system, and as he left, he advised my I would need to bleed all the radiators, at some point, given a few days, when...
