Discuss Logic+ 35 no hot water help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
ajplumbing
Hi guys
in of a little bit of help got a problem with the above boiler giving no hot water.
So as you would change the flow turbine that had disintegrated and the magnetic sensor on the top and still know luck but the red neon lights up. Next step was change the pcb so have done that still no life from it. Back on the phone to ideal, thought the problem could be the sensor from plumbs it was a clear base with a red top instead of a black base and clear top and it being in Wosley packaging thinking its a Center brand one, so have just changed that still no life but the neons gone intermittent now (flashing).
next step is the wiring harness but checked it both ends and between the black and red is 5v and between black and blue 5.5v when stationary but nothing when the tap is running. Just at a little bit of a loose end and wanted to know if anyone out there has had a similar problem
Boiler hasnt been been serviced and not in a clean condition
Build your post count up to 10 + then send a message to [email protected] with an image of your gsr card.
Then you'll get access to the private forum where we'll help you.
We do not discuss boiler repairs in open forum.
Reply to Logic+ 35 no hot water help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
