Discuss Logic Accredited Course! Yes or No? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I am looking to a gas engineering course which apparently is a Logic Accredited Course and at the end of it i will receive a logic certificate. And i then do a re-assessment every 5 years.
Can anyone tell me is this certificate a recognised qualification and will it allow me to register with Gas Safe and start their probationary period.
Have you any past training or plumbing experience?
yes as long as you pass all the relevant courses that you have applied for you must undergo training first before you can be assessed on a logic accredited course
I am going to be completing BPEC Level 2 in Domestic Plumbing and a BPEC Level 2 NVQ in Plumbing - you will also complete and receive a WRAS Certificate and an Unvented Hot Water Systems Certificate. And hoping to complete Gas with intention to register with Gas Safe but never heard of logic certificate so didn't believe it was correct.
You would have to complete level 2 first and to complete that, you will need to be working with a qualified engineer for a year and a day and complete a work based portfolio. This is before you can get gas safe qualified.
after you have passd you traning at college you will be assesssed at a logic accredited course if you pass this you can apply for gas safe.
Thank you well once i have completed the courses i am hoping to have a workplace lined up to enable i complete my portfolio. appreciate the advice
Thank you for that i believe that is lined up for once i have had a work placement then go for the assessment/exam
32 years for me!!
To the op.
Don't wait until the end of the two years to get a job. That's what eveelse does. Go look for one Now. Start working weekends, or take it full time. College will adapt.
Reply to Logic Accredited Course! Yes or No? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Locked
Hi, A little about the business: I currently own a plumbing business (website and marketing) - looking to target residential and commercial market (i.e. tendering to main contractors flats etc). My background is a commercial manager, I use to do plumbing years back so technically I would not...
Hi, Hoping some of you folks can steer me in the right direction. I have been self employed for the last 15years supplying services to the industrial gas market. That ranges from installing cryogenic storage tanks, pumps and pipework to high pressure Hydrogen systems and bulk LNG. My work has...
Hoping somebody can help, So, in a nutshell… Standard 90s Westbury home – condensing boiler, pump, wall thermostat, etc etc... Normal, common or garden, run-of-the-mill British housing estate CH setup. Downstairs radiator, 1 of 2 in our living room, went cold one evening mid-November last...
Hi there, I am currently in the forces looking to leave in the next year or so. i have a level 3 apprenticeship in electrical and mechanical marine engineering and realistically i have no issues tracing systems and working out whats what. the dream is to leave the forces and become self...
1K
W
Hi all, I've got a bit of a strange issue relating to my Ideal Logic Combi 35 which has recently started displaying a F2 error when trying to use the central heating system. The boiler works fine when using hot water, however when I try to turn on the central heating system the boiler works...
Williams25
W
