Discuss Looking for ASHP install commission in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Stoney Ground
Stoney Ground
I am doing a job in Sussex, and will be installing an ASHP, looking for someone to do refrigerant side of system.
Don
Reply to Looking for ASHP install commission in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The MJ3 Charger on my Mainsboost system has stopped working and I have sourced a replacement, but need a plumber that understands these installations to come and replace that unit and ensure it's commissioned properly. Let me know if you've worked with this system before and can quote on...
I'm planning to get an air source heat pump (ASHP) installed and I'm considering my options about the location of the water cylinder as I live in a small house and space is a premium. I was thinking about building a small insulated shed about 20 to 25 metres away from the house to put the...
2K
DIY air conditioning system. I've got lots of plumbing experience and want to install my own a/c split system 3 to 1. I intend having it commissioned by an F Gas qualified company. When l tried to buy the system the supplier want all details of the F Gas registered 'installer' before releasing...
Helping to audit an electric-only house with ASHps -NIBE kit installed into the new house in 2012. 2 ASHPs outside -each F2015. I put on some monitoring of their electrical usage -each takes 40W night and day 24/7. It's August so they are off 99% of the time: but when off, still use 40W...
Not sure what my options are here. Basically a friend of mine recommended his father in law to do our plumbing/gas work for our renovation. First job was to install a new boiler, and later install radiators, bathroom, kitchen, etc. The boiler was installed last September but not switched on as...
2K
