Discuss Low mains pressure, need ground level header tank? in the Plumbing Forum area at UKPlumbersForums.co.uk.
Tags:
  1. JimC
    JimC New Member
    Hi, I get my water from the nearest farm. So pressure is very low, have recently had a loft conversation, which means I have no room for a header tank.
    Can I install a header tank in my brick shed, near the mains meter with a pump to get the required pressure to the first floor?
    Do I have to leave cold taps on the standard mains, or just the kitchen one?
    Many thanks for your help.
    Jim C
  2. Chalked
    Chalked Plumber GSR
    Fit a DAb esybox.
    Not cheap, but will cure the problem.
    • Like Like x 2
  3. ShaunCorbs
    Yes you can as above easy box and separate tank
    In regards to capacity of the tank go for the largest you can afford / fit
    And you can have the whole system off the tank and pump if you would like
    • Like Like x 1
  4. JimC
    JimC New Member
    Hi Chalked / Shaun,
    Quick google says a typical bath is 100 litres. As that is the biggest single item that will need filling, and the fact that the header tank will start filling as soon as you start using it, will the below be sufficient?
    20 Gallon / 91 Litre Cold Water Loft Tank
    and will this pump be suitable?
    DAB E.SYBOX Mini Booster Set
    Many thanks for your advice :)
    Jim
  5. ShaunCorbs
    I would go for if you can 200l and yes that's the pump
    • Like Like x 1
Loading...
Similar Threads - mains pressure need Forum Date
Are any fittings allowed on mains in before the stopcock? Water Regulations Friday at 11:47 AM
How does water in mains pipe make a noise like water running? Plumbing Forum Aug 15, 2018
