Discuss Low temperature emitters in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all
Could anyone give me a ballpark, very rough cost for upgrading of radiators in an office of about 5,000m2 to low temperature radiators ( running at about 40C ), assuming minor pipework modifications for each radiator - including supply of the radiators + time and materials?
Just looking for somethinbg very rough for now...
Nick
Do you know if the radiators are sized or 40dc
And what's the pipework
Have a site visit shortly to survey the building. At the moment I am looking at approximate financial models to determine ballpark viability. Could you give me a typical range of costs?
10k-50k
It's a shot in the dark with no info get a few quotes from commercial heating engys as it needs to be designed right
10k-50k
Thanks... I know its a shot in the dark, but is that based on supply of the low temp radiators and installation or install only?
Don't know lol like I said it's a shot in the dark
Your guess is a good as mine get some contractors in and get them to quote it
Understood.. as a shot in the dark what would it cost to for installation and removal of 250 rads only ( assuming supply elsewhere and a moderate amount of pipework mods..?
You need a Commercial Heating Engineer to come and measure up to price that.
What's the reason?
If it is to prevent people touching them, why not price for purpose manufactured covers?
I do not mean the type of thing you see in domestic premises.
Some Radiator companies, will manufacture LST covers for rads. I think Stelrad do them! That will save major alterations.
Like I said at the start though, it's a specialist job and needs assessing by an experienced Commercial Engineer.
The reason..... existing radiators will be sized for higher water temperatures, the system will be using water temperatures of lets say 40C so will need to be bigger to cope with building heat losses. I know I need to get quotes in but this is an early stage project and I just need a ballpark figure for my financial model to take it to the next stage where I can firm up costs.
Ballpark figure.
ÂŁ180 per rad cost.
ÂŁ100 per rad to aalter. It will be more than minimal alteration, as the rad will be 30% larger.
So ÂŁ70,000.
Reply to Low temperature emitters in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with venting through the external wall and I'm reluctant to go with an electric boiler instead (because of the consumption cost)). It's a sealed system. The...
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was not working. He changed both valves and still the radiator was not working. He put some chemicals in and said it should break up anything that is...
Hi everyone, Just wanted to share my experience with "upgrading" an S plan setup to Opentherm and Vaillant Control Center (VR66). There are a few threads on a few different forums but I wanted to share a full write-up with all the steps needed, benefits and costs. Overall, I fully recommend...
1K
Hi there, thanks for taking the time to read this. I've been trying to diagnose why my gas consumption is so high and been doing various measurements and tests. With the UFH, my setup is about 10 room zones connected on two separate UF manifolds linked to one UF pump with a return blending...
4K
Hi, Looking to see if anyone can give some advice please. My Baxi boiler has been losing pressure and I am having to top it up approx. every 4 hours from 0-1.5 bar each time. This has been going on a week now. I have also started to notice small drips running down my condensate pipe...
