Discuss Macerator only toilet in rental in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. revelation2112
    revelation2112 New Member
    We're renting a property and the toilet is a Saniflow that seems prone to blocking. We had a Saniflow engineer advise that this is due to a weak flush and waste not even reaching the macerator. However landlord got another saniflow plumber out who advised it's fine and that we need to blank flush every now and then and also use a cleaning solution to break stuff down. Advice I'm a little sceptical about.
    I understand that at the moment having only a macerator toilet does not meet building regulations but it did at the time . However both our sink and shower also drain into the macerator so we have no wash facility not connected to it. Does anyone know if this is or ever was allowed?
    Our bath waste seems to be pretty much an open waste pipe, kind of gross if that's also connected to the poo pipe.
    Apparently due to the layout of the pipes etc a macerator is the only option in this flat. However , I would imagine that if the landlord spent enough money they could install whatever they wanted ?
  2. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    I am not a macerate expert but there is one on the forum. I am sure he will be along at some point to answer your questions.
  3. ShaunCorbs
    • Agree Agree x 1
  4. Harvest Fields
    Thanks Shaun forgot who it was
    • Funny Funny x 1
  5. rpm
    rpm Trusted Plumber
    Common problem of an incorrect installation with a model favoured by landlords. Saniflo engineer correct, Saniflo plumber owned by the landlord!
  6. rpm
    rpm Trusted Plumber
    Not allowed in the last 20yrs.
    Poo pipe? Please explain more.
    Unless it is in a basement then yes most likely.
  7. revelation2112
    Thanks, never saw your reply before. We have had it block again on Xmas day! Got it to clear by running the shower and then flushing at same time.
    Appears flushing as normal now except air bubbles after flushing and also it was like this for a few day last time and then blocked big time.
    Another thing we have noticed is that shower always backs upvslightly and then takes a few seconds for the macerator to kick in and then drains.
    If you give us any help or advice as to what to say to our landlord that would be a massive help.
  8. revelation2112
    Hi, would you be able to explain? Thanks
Loading...
Similar Threads - Macerator toilet rental Forum Date
Worn doughnut washer for toilet cistern Plumbing Forum May 29, 2018
How to offset toilet to left of soil pipe Plumbing Forum Apr 1, 2018
