Discuss Mechanical Forman rates in the Plumbing Jobs | The Job-board area at PlumbersForums.net
gasmanrob
Just wondering what the going rate was for a working Forman on mechanical been offered a position but rate seems real low
thanks in advance
£16-£20
Self employed or on the books?
Maybe more on bigger projects but if you are lacking experience then foreman may not be the best place to start.
18-20 per hour down in swest
Have several friends who foreman jobs out on commercial side and this is what they pay project depending.
On site as general idiot plumbers will get between 15- 18 per hour now
Do you have to change your name to Adam, and drink out of little glasses with umbrellas in them?
I suppose it dependd how big yhe jobs are if they are smallish then less stress , consider hoe much you need continuity
Not gone for that role as such have been in 2 days of negotiations regarding pay and conditions. And have agreed I wont be working forman but occasionally a charge hand weekly reports on progress and placing phase material requisitions but that is only when there is a large project on and will include additional payment. I will predominantly be a service and technical got a good wage out of it considdering my experience more then I should be but less tgen I could be. Putting me in for refcom as well as commercial tickets.
Oh by the way im commercial. .
Reply to Mechanical Forman rates in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, i moved recently in new home and realised that there is no room external thermostat wired to the Ideal Combi boiler. There is only mechanical timer on it. I saw some videos on Internet that mechanical timer can be replaced with electrical one but i am not sure if it is compatible with...
Dobsuk
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the cause. I would like a flow rate of about 12L/min. Here is my set-up: Standard gas boiler (not a combi) in the kitchen, have cold water tanks in the...
Essaboy
E
I've just replaced an Ultra SASF2 – M thermostatic shower cartridge together with the spring mechanism and the temperature sensor. My problem is this: If I install the thermostatic cartridge together with the spring mechanism and the temp sensor (i.e. do the job properly), the shower runs warm...
Hi Could I ask for some help with a water flow rate problem. I have good mains water pressure on the ground floor. There is no tank in the loft but an unvented cylinder in the upstairs airing cupboard. A gas heat only boiler. Upstairs I have two en suite rooms. One with a shower and one with...
The User Guide etc states an available temperature range of 25-80c. Various instructions found online instruct to turn it fully clockwise to display maximum 80c, then back it off and stop at desired flow rate, ie 55c. However, turning the dial fully clockwise (hottest) displays maximum 30c, and...
