Discuss Mega flow system losing water pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Firsr time post apologies if it's been covered.
I had a mega flow system fitted 9 months ago and if I'm in the shower for example and flush the toilet the pressure drops.
Same if I'm running a bath and turn the kitchen tap on, the pressure drops quite a lot.
I had a total house renovation and my builder is scratching his head and saying it's just how it is.
But I know that it's not.
Any tips and suggestions would be appreciated.
Easy what's your incoming cold water main pressure and flow readings ?
And hope the builder didn't fit the unvented cylinder
Hi. No idea. How would I find that out?
Also the pressure is fine with just one tap running. Really good pressure.
from the cold kitchen tap or outside tap how long does it take to fill a 1 or 2 l bottle (which ever you have handy)
as for pressure you would need to get a pressure gauge
http://www.NoLinkingToThis/p/monument-tools-mains-water-pressure-test-gauge/82412
attach to an outside tap
and measure the standing pressure (with no outlets open)
and dynamic pressure (with the kitchen tap open or one outlet open)
hope this makes sense
Monument Tools Mains Water Pressure Test Gauge
12.5 seconds to fill a 2 litre bottle.
theres your problem around 10lpm way way under what is needed for an unvented cylinder, spec is a min of 20lpm
can you double check that measurement by using an outside tap
Previous was kitchen tap.
Outside tap = 8 seconds for 2 litres
thats better but still lower than needed for an unvented cylinder
outside tap come out at about 15 lpm
i would say incoming water main is your problem
do you know what size and material type is it ?
No idea sorry. I'll have to get all that looked at.
Someone else suggested an accumalator might solve it. Does that make sense?
depends it would solve the drop in pressure when more than one outlet is open (wouldnt increase it) its an ok idea need to know what the incoming water main pipe is tho
wheres your cylinder located?
Cylinder is in converted loft space, in its own room. So technically the 2nd floor(top floor) of my house.
bit of a long shot any chance of a few pics of the cylinder and pipework etc?
stop tap open all the way up both of them?
Wouldn't surprise me if a least one small bore isolating valve is fitted on mains supply or outlets. I don't trust builders and their plumbers
Plumber returned and he measured pressure and he's getting 21 lpm at the boiler. He's scratching his head as it should be more than enough pressure.
Plumber returned and he measured pressure and he's getting 21 bar at the boiler. He's scratching his head as it should be more than enough pressure.
Guess you mean 21 lpm ? As 21 bar would blow the cylinder up :D
Builderitis...
Best measure output from three taps. Open three taps fully and measure how long each takes to fill 1 litre. That gives you the true system ability. Then see if you have your 20 lpm.
Also, what size is the incoming main and the pipe at the stop tap? 15mm or 22mm? Does it reduce down to go up to the loft?
Reply to Mega flow system losing water pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can central heating / gas engineer expert help me with below issue. During winter time only, I have been having issue with low pressure or pressure dropping with unvented hot water cylinder system. During summer time there is no usage of central heating so the pressure at unvented system is not...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air gap as I was having dripping from the pressure relief valve. Since then I've lost a lot of pressure from the hot water feed to my shower. The rest of...
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a megaflo unvented indirect cylinder (125i) boiler is a Worcester greenstar. I have good pressure on the cold feed and all the usual stuff works, taps...
Hi all not a plumber but am an engineer I have pressure drop in the system Worcester Bosch came back after repressureising the expansion vessel and he replaced the heat exchanger element. The boiler is coming up for 15 years old. The boiler was going below one bar and not increasing when...
Good afternoon, I am experiencing a pressure issue with my heating system and was hoping to receive additional insight as to what the problem could be. We have a biomass boiler and stratification tank set up and recently had an issue with boiler pressure dropping off when the system was cold...
