Discuss Megaflow combination valve Deptford London in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Reply to Megaflow combination valve Deptford London in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I am looking for a heating engineer to diagnose and resolve an issue with my Vaillant EcoTec 832 combi boiler. Job Location: Copeland Rd, London. Job Description: Problem: The boiler is not providing heating under normal conditions, although hot water supply is fine. Interestingly...
R
I just had installed a Navien NPE-2 with built in recirculator pump. I have a dedicated return line. The check valve for the recirc is built into the unit; a spring check valve was placed on the cold line (per the manual) after which there is an expansion tank (on the cold line) in a T junction...
Rogelio
R
I recently read a post / comment whereby there was a recommendation that if you are away from your home more than 24 hours, then you should turn the water off to avoid potential catastrophic damage. When I go away I have always tended to turn ours off, that's typically anything from a couple of...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise coming from my copper water pipes when no water is being used? It basically sounds like the noise you hear after the water shuts off when your toilet bowl...
Hi all, Got a strange grating noise when the mains water is running in a property I'm looking after. It's a ground floor flat, with a first floor flat above it, and both share the same mains water pipe, and I believe the stopcock behind the washing machine isolates all water to both properties...
