Discuss Mira ATOM ERD - fixing kit? in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
Tags:
  1. Mike Scott
    Mike Scott New Member
    Hi all
    Just wondering if anyone has had any success installing a Mira Atom ERD with a bar valve fixing kit (eg the Bristan bar valve fixing kit). If so, which kit have you used?
    I've bought the Bristan kit, above, but the technical spec for the shower states that the offset (Z) connectors need to stick out between 40 and 43mm from the finished wall. The Bristan kit only seems to be able to manage around 30mm. I'm presuming the 40-43mm restriction is dictated by the length of the attachment at the top of the riser to the shower rose..
    I'll use the supplied offset/ Z connectors if I really have to, but only as a last resort - can't stand the bloody things.
    Many thanks in advance
    Mike
  2. ShaunCorbs
    easy way to tell but sometimes due to tiles thickness it becomes a pain
    fit the shower to the fixing kit and measure the distance left between the cover plate/vanity cover and the plastic mesh
    dont forget about your adhesive
    • Like Like x 1
  3. Jaimie Hammond
    Jaimie Hammond New Member
    • Like Like x 1
  4. Mike Scott
    Jamie - you're a life saver!
