Discuss Mira atom erd problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
I have a bar shower mira atom erd
The problem is the brass thread under the bar shower wher the hose is screwed on to its leaking from inside and drippin from side of the thread. I hope you understand. Mira advised change the temp cartirage and still same problem matter of fact worse
There is a video on youtube showing exavt problem but does not show how its fixed
Please help really annoying
Hi
Under warranty?
Ah
Its not leaking from ther
Its dripping from the side of the brass thread the hose is screwed on to
If you put yur finger over the the hole wher the water comes out of the runs down side of the finger i hope this makes sense
or get an allen key and tighten it
prob loosened it when you've undone the shower hose
Hi
Did you ever fix this? I have the same problem. I replaced the flow diverter cartridge with no effect.
This is either a design or manufacturing fault. Mira knows about this. I had 2 brand new ones installed and both resulted in the same issue. Apparently, all their showers use the same valve. So, even if you replace it with another model, it will result in the same fault. I would suggest buying another brand
Reply to Mira atom erd problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
