Discuss Multiple mixer showers in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. offgridman
    offgridman New Member
    OK folks, here is a brain teaser.
    Just been asked to look at a bungalow that has been subject to recent renovation/ modification by a variety of persons.
    Water supply is from private borehole, into property in 25mm MDPE at an indicated 2bar pressure. DHW storage is 206 litre cylinder with immersion heater, solar thermal input and connection to oil-fired (pressure jet) Stanley Superstar range providing DHW and CH. Estimated DHW pressure based on existing header tank position is approx .2 bar.
    Someone has fitted 3 x thermostatic mixer showers that are not going to work on gravity alone, never mind the restricted CW supply.
    Looking for sensible solutions re pump assistance and obviously additional tank capacity both with cylinder and cold supply for showers. Personally, looking at this, I probably would have said 3 x pumped electric showers may have been a better option at start, but I wasnt there at the beginning. Owners expecting to rent out as holiday let so simultanious shower useage very likely
    Suggestions on a postcard please.
    Thanks.
  2. ShaunCorbs
    3.5 bar uni/negitive pump should do the trick
    or convert the system to an unvented cylinder and fit a higher pressure bore hole pump
  3. Matchless.plumb
    Matchless.plumb Trusted Plumber GSR
    I'd convert system to unvented cylinder as above mentioned
  4. king of pipes
    As shaun as said fit a neg head pump it really depends on how much storage of cold water you have cheers kop
  5. offgridman
    Thanks for info so far guys. I'm thinking current cylinder capacity may need to be increased anyway bearing in mind potential demand, and additional cold water storage is no doubt required.
Loading...
Similar Threads - Multiple mixer showers Forum Date
Thermostatic Mixer bypassing Plumbing Forum Apr 10, 2018
Leaking Mixer Problem Valves & Taps Apr 8, 2018
