Discuss MY TOOLS STOLEN AGAIN in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Tools stolen and i saw them on my cctv must of cloned key fob
lights flashed as they do on unlocking then doors where opened and tools and other things taken, off to get security locks for the doors. advise you get them fitted before it happens to you.
Pete
Pete
What van you got?
Feel for you mate , I worry sometimes when mine is left, I am seriously thinking of removing the sign writing off mine . Thing is the little sh!ts cant bloody read so they would probably rob you anyway
Lot of tool thefts going on now, check out the facebook group van and tool theft awareness
Got a ford? If so they didn't have a key they used a pair of grips. Two twists of drivers door barrel and it unlocks all door and turns off alarm like normal key does. Check out YouTube if you have a ford and gets some extra security. Apparently you can also get an ecu update to help but ford charge you for this even tho it's there own design fault.
Got to have dead locks fitted nowadays, YouTube is again your friend.
Unless they have a grinder or oxy :D I only say as that's how mine was done
Twunts still get round deadlocks! Managed to get mine open a couple of weeks ago. Unfortunately, on Scudo/Expert/Dispatch, there's a switch at the back of sliding door which unlocks rear when they prise door open about half inch. I've since relocated the switches on mine.
Consider marking your new tools with a Smartwater kit. I believe it probably does reduce the chance they'll get pinched in the first place and increases the chance of prosecution/return if someone is caught with them.
Not as effective as a dog with big teeth, I suspect, but then not much is...
Reply to MY TOOLS STOLEN AGAIN in the Plumbing Jobs | The Job-board area at PlumbersForums.net
