R
Robaxter02
I have UFH heating downstairs installed new just over 2 yrs ago but I think one of my actuators isn't working. When the stat is turned on the red indicator doesn't lift so I'm thinking the actuator is damaged. The flow meter is working for the room when you remove the actuator but something's just not right. Currently it's way too warm sitting at around 25deg. Is this a simple actuator change out? Is there any way I can check to see if there is any other problems? All other rooms work fine. The system is on a 10 way manifold of each of the zones and the pump is working fine when I adjust the room stat.
