Discuss Mystery valve on CH primarys in the Central Heating Forum area at UKPlumbersForums.co.uk.
Tags:
  1. Tom Williamson
    Tom Williamson New Member
    Can anyone help identify this valve. LH 28mm is fed from a Ideal Mexico (being removed). HW is (was) gravity on separate 28mm so this is just heating only. I realise there will have been a handle at some point.
  2. ShaunCorbs
    Looks like it could of been an old servowarm selecter valve
  3. Tom Williamson
    Would it have the capacity to incorporate a solid fuel fire with back boiler?
  4. ShaunCorbs
    Would say no
  5. Tom Williamson
    Pipes dissapear under a concrete then laminate floor so having difficult to identify what all 4 do. Flow from Mexico, then maybe upstairs/downstairs heating but can't work out other?!
  6. ShaunCorbs
    I would say fill and safety vent combined maybe
  7. Tom Williamson
    Traced Feed and Vent on the HW primarys so they are separate,still stratching my head!
  8. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    What do these letters say?
  9. Ric2013
    Ric2013 Plumber
    GKN on the bolts? Doesn't GKN make car driveshafts?
  10. Harvest Fields
    Looks like s***N
  11. quality
    quality Plumber GSR
    S-GM-X proportioning valve
  12. Tom Williamson
    Customer had found original documents from 1963. LH is flow from boiler. Up is Upstairs heating, down is downstairs heating and RH 28 is tee back into return, so a bypass. Pretty clever stuff
  13. Harvest Fields
    Was about to reply that the only thing I could find remotely close was an old Sloan valve
Loading...
Similar Threads - Mystery valve primarys Forum Date
How to top up Stelrad Ideal boiler? Mystery hose... Central Heating Forum Tuesday at 10:10 PM
Leak from CHS mystery outdoor pipe Central Heating Forum Jan 22, 2018
