Discuss Need a 3-way kitchen tap. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
steve1
We have a water softener installed and have left the cold tap in the kitchen as our designated drinking water tap, but we have softened water their as well for the dishwasher, and outside tap if I require for car washing.
Basically I want to install a mono block tap with 3 levers, one soft hot, one soft cold, and one drinking water.
I know you can get taps that come with a filter system etc, but that's a waste for me as I already have soft water, and the way they work I would be simply filtering soft water, ( I think ).
Are there any straight forward mono block taps out there that are simply 3 way.
Reply to Need a 3-way kitchen tap. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Plumber had fitted a new mono kitchen tap. The hot water takes ages to get hot if at all. The on lever hadn’t much turn on it and it’s at full throttle. Also when I point tap to bowl with fairy liquid in, it doesn’t have enough power to make bubbles
Hi I have a leak on my kitchen tap it is coming out off the bottom of the cold lever. How do I get the lever off? Also would this tap have a cartridge in the cold & hot or will it be just tap has had it & I need to get a new one?
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied from cold water tanks in the loft. It is a vented system. However, in a basement flat and a ground floor flat cold water supply to bathrooms is...
I have a kitchen mixer tap with quarter turn levers and the cold side started dripping. I took out the ceramic valve and replaced it with one from Screwfix but it hasn’t solved the problem it still drips. Could it be a dodgy valve or is it something else? Thanks
Hi everyone, I need to replace the kitchen tap, all my neighbours have two single taps in their kitchen and bathroom whereas I have a single lever tap in the bathroom and kitchen. Due to living in a flat and having a shared water supply I was advised to get a dual flow tap for the kitchen so...
