Discuss Need help with a leaking diverter. in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi all. My first post. I am renovating an '80s condo and the diverter is leaking. I tried to unscrew the outer cover but it seems stuck.
I don't want to damage anything and hope to fix my self. I did get a qout to change out the three handel system to a one handel with a remodlers plate, but th e estimate was $900.
Any ideas of the type of valve and a compatible replacement?
Thank you
Reply to Need help with a leaking diverter. in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
I assume the answer is no, but if this fixes the issue I know it will be what my builders sub contractor plumber will do. Therefore, before he is...
1K
Looking for a bit of advice regarding the shower diverter valve on my bathtaps. Pictures attached. Problem is that when I run the taps to fill...
4K
Hello everyone Before I succumb to this problem I’m reaching out for some help. There’s very little info on the web and I can’t get hold of a...
2K
Hi all, This may be a slightly lengthy one, but i'm having a seriously rough time with a bad leak in the ceiling of the downstairs bathroom...
3K
