Discuss Need new TRV head unit in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all,
I have just moved into a new house and it looks like the previous owner has taken all of the TRV head units with them. I'm trying to get new ones, but the valves appear to have threads. Is anyone able to help me identify these (see attached)?
Thanks!
Jamie
Jamie he's not took them, they are old valves, heads have stopped working you will need to replace all the valves, even the radiators are looking in poor condition, is this your own or rented ? if your own you should have got the system checked B4 you bought it, if rented then it's the landlords problem.
Look like old Honeywell ones
Barlo/Quinn or Caleffi. Best to replace altogether.
Reply to Need new TRV head unit in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Afternoon all, I have a customer with a heavily extended semi which now has 4 beds, 2 bathroom and 5 reception rooms. They have started working from home and want to zone the heating system, unfortunately the system boiler and cylinder is in the garage with 2 x 22mm primary pipes disappearing...
Hi I am trying to fit a Hive Radiator valve into my existing TRV valve body to make them automatic so have bought a Hive valve to try it out. I have done this before in another install but the valves were Danfoss and directly compatible with Hive. I am looking for an adapter that will be able...
Hi - I'm a reasonably experienced DIY plumber but just can't work out why the last new rad I've installed is cold - would really appreciate your help please. I've extended an existing 'run' of radiators - the last one on the run ( in downstairs kitchen) is cold. The first rad added is...
Hi all,new to the forum and hoping to get some guidance through the boiler minefield . We moved into a 70s bungalow last Feb,its got a Greensted 241 junior mark 3. The expansion tank has failed, also it has a Boss therm sender unit wired to it but the previous owner didn't leave the receiver...
Hi, I just moved into a new house and it has a Glow Worm Compact 24c combi boiler and a ESI ESRTP4RF+ programmable room thermostat and I am wondering if it's worth turning on the optimum start and stop features? There is also something called TPI (chronoproportional control) but I'm not sure how...
