Discuss Need suggestions for a pump to boost domestic hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Need suggestions for a pump to boost domestic hot water, from the source at the immersion cylinder.
thanks
Any Stuart turner. If you're not concerned about unbalanced pressures then you can get away with single impellar
I think they start at about 1.3 bar it would probably be best to get a professional to look at the state of your joints to say whether or not you should go higher than that
Don't ave facility to measure the pressure what would be the typical pressure from a loft tank..
Not sure if I could raise the tank, or how much I would need to raise it to get a reasonable increase in pressure..
Thanks again
Thanks again
Thanks again
The higher you raise the tank the more pressure you will get ... for each metre you will get an extra 0.1bar pressure ...
Increasing the height of the tank is fairly easy...but you need to make sure the entire base is supported.
Thanks again
Reply to Need suggestions for a pump to boost domestic hot water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Has anyone one fit or serviced one of these before; Heatrae Sadia 25l 9004010. It a 25 litre hot water storage cylinder.
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
