Discuss Need thought on how to open up single lever tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. We moved into our house last year and the kitchen tap has been dropping since we've moved in. Finally getting around to looking at it! I'm guessing it's just needs a replacement washer or something, but I can't figure out how to open it up. Any ideas?
It's a Swan neck tap, with a single lever block to the side. I can't seem to get to the screws inside the lever block. And there's a small screw on the back of the neck area. Have tried unscrewing but the neck doesn't come off. I don't want to force anything in case I break it.
Have attached some photos. Any suggestions appreciated. I don't know the make or model of this tap.
20180330_110849.jpg 20180330_110853.jpg 20180330_110915.jpg 20180330_110933.jpg 20180330_110946.jpg
Easier just to change the tap. That one will need a new cartridge. Fine if you know the make.
As above but if you really want to the where I have circled in the pic. The little cap will pop out and will expose an grub screw inside. Loosen this and the lever will pull off and expose the cartridge
Reply to Need thought on how to open up single lever tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I need to replace the washer of my kitchen mixer tap as it is leaking. I was able to remove the spout once by unscrewing the screw on the back of the tap. However now I can't remove it again as it seems I must have used the wrong screw head and have rounded off the head. Please see attached...
Hello folks, I’m trying to fix this slow leaking tap myself and I’m stuck here. How do I dismantle it further to replace whatever needs replacing to fix the drip? (The chrome ring round the top will not unscrew by hand.) Many thanks
I’m trying to replace a cartridge on a Grohe mixer tap but I can’t get beyond second stage! I have removed the grub screw,but cannot lift off the lever.I have applied some wd40 into the grub screw hole,..but the lever won’t budge. is there any other method for removing the tap lever?…help...
2K
Hi everyone, I recently had a Hansgrohe wall mounted single lever basin tap and a Hansgrohe thermostatic concealed bath/shower valve installed (full bathroom renovation). The basin tap started dripping a few days after installation. But it stops dripping only when shower is turned on. Any...
I need to change the washer on the dripping hot tap in the photo, does anybody know how to remove the dome tap handle, there's no fixings or grub screw anywhere, thanks
