Discuss Need to source some valved domestic brass manifolds . in the Plumbing Jobs | The Job-board area at PlumbersForums.net
king of pipes
Subscribed
As above need make up 2 - 12way valved manifolds for a project but its proving expensive anyone know of a supplier ? Regards kop.
hot and cold? or heating?
Hot and cold shaun , made the heating ones up with copper tees scott but its all top end showers counter top basins wall mount taps fancy units so need isolation.
Cheers kop
They look ideal shaun thanks mate 24 15mm levers comes out at Ā£153 bit much so hopefully these will work . cheers kop
Reply to Need to source some valved domestic brass manifolds . in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know a good, not super expensive, leak detection company in the London area?
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
