Discuss Neostrahl tap leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
as1981
All,
I have one of the taps shown in the attachment. I can't find any way of opening it to repair the leak. Could anyone advise?
Thank
Andrew
Can't help with that, sorry.
But I can tell you, that I had a problem tap and the only name visible was Neostrahl on the nozzle.
They come out, and on my tap the name only applied to the nozzle, not the tap.
There might be a very small grub screw at the back.
Reply to Neostrahl tap leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Please can someone advise how to fix this shower that leaks? I guess I need to replace the washers inside the taps. Is it the blue or red one? My local DIY place didn't have the washer last time I attempted this. The cold tap is the culprit, a bit soft to tighten and leaks unless really tight...
I have a slow leak in the bath. Its a mixer type set up. I'm unfamiliar with the tap handles and how to access the cartridges etc. If I can work out the product name/brand/type then I can work out how to remove the tap handles (no obvious indices so presuming they pull off some how). Would...
Hello, I need some advise, will greatly appreciate if someone can help. My mixer tap is leaking from base want to renew it. However the tap cold/hot water feed is connected via connectors/fittings as shown in attached picture. Can anyone please advise how to disconnect tap from these fittings as...
Hi there I have attached a video below, showing where my kitchen tap is leaking from, is this possible to repair by replacing the hose pipe or would I need to replace the whole tap? I had a plumber take a look who said the whole tap needed replacing. If it is just the hose supply do I...
Hi, My Blanco Kitchen Tap Model Swift BM1420 is leaking. Please see attached photos for details of where water leaks from. What I've done so far. I replaced the cartridge. Leak persisted. Bought some replacement seals and tried to put in place of the old ones. Here's what I did next. Remove...
