Discuss Nest E thermostat .................... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scott_D
Subscribed
Anyone fitted one?
Whats the difference between the new one and the 3rd gen?
in summary cheaper alternant
Reply to Nest E thermostat .................... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I have just bought a google nest 3rd gen thermostat to be connected opentherm. I currently have the baxi ifos rather comp fitted. I was told that it was either one or the other, but baxi technical dept have said I can wire an opentherm controller alongside the ifos system. Boiler is...
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised valves simple bi-metal thermostat on wall in flat with 4 standard TRV's rarely used so not worried about the flat, and main house has Nest Gen 3 in the...
Hi, I'm looking for a confirmation before I purchase Google Nest Learning Thermostat that it would compatible with Sime Brava One 25 BF over OpenTherm connection. If yes, I would love get some directions on how to do it. Thanks.
Hi guys, I have a set up with rads upstairs and UFH downstairs. I have installed the manifold for the UFH along with 2x Honeywell 2port values, one near the manifold and the other on the radiator side. I will be using Nest 3rd gen thermostats to control both the upstairs radiators and...
2K
We have recently moved into a property which has a Worcester Greenstar Highflow 440 Standalone Combi gas boiler. This appears to be a relatively old unit however, it is still in great working condition and has been serviced on a regular basis. I'd like to add a Nest Thermostat to control the...
