Discuss Nest install help :( in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Rothers
I have a Worcester Greenstar 30Si and I'm trying to install the Nest Thermostat. I'm under the impression the case is a sealed unit can anyone confirm that for me please?
If so, can I get to the wiring without breaking the seal. I'm fine with electrics but boilers aren't my thing and I don't want to damage it. I can't see a way to remove the front panel .. :thumbs_down:
Need a gas safe engy as case needs to come off with most
What version of the si do you have can you take a pic of the controls under the flap ?
Greenstar 30Si COMBI Mk IV
Condensing boiler
Does that help?
That model is case sealed so you require a gas safe engy sorry to say
Reply to Nest install help :( in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Fellow Engineers I've attached a wiring diagram I've just completed, I wanted to make sure I've got it correct. Looking to install 2 Nest thermostats to a Worcester combi boiler. 1 Zone is radiators and the other is UFH, with pump on manifold Would be grateful to receive feedback. Thanks
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised valves simple bi-metal thermostat on wall in flat with 4 standard TRV's rarely used so not worried about the flat, and main house has Nest Gen 3 in the...
Hi everyone, Just wanted to share my experience with "upgrading" an S plan setup to Opentherm and Vaillant Control Center (VR66). There are a few threads on a few different forums but I wanted to share a full write-up with all the steps needed, benefits and costs. Overall, I fully recommend...
1K
We have recently moved into a property which has a Worcester Greenstar Highflow 440 Standalone Combi gas boiler. This appears to be a relatively old unit however, it is still in great working condition and has been serviced on a regular basis. I'd like to add a Nest Thermostat to control the...
I've got a Baxi 600 combi, with a Google Nest thermostat, fitted a year ago. I've just learnt about OpenTherm, so went into my Nest settings, and found that it is disabled (only on/off mode is selectable, OpenTherm gives an error message). I spoke to the installer who says that he never...
1K
