Discuss Nest S Plan wiring into 2 port valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello,
Looking at the nest s plan wiring diagram, what does the BW wire stand for on the 2 port valves?
Thanks!
That drawing is wrong
What set up do you have now ?
This is the one I use
Reply to Nest S Plan wiring into 2 port valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone, Just wanted to share my experience with "upgrading" an S plan setup to Opentherm and Vaillant Control Center (VR66). There are a few threads on a few different forums but I wanted to share a full write-up with all the steps needed, benefits and costs. Overall, I fully recommend...
1K
Hi Fellow Engineers I've attached a wiring diagram I've just completed, I wanted to make sure I've got it correct. Looking to install 2 Nest thermostats to a Worcester combi boiler. 1 Zone is radiators and the other is UFH, with pump on manifold Would be grateful to receive feedback. Thanks
Hi guys, I have a set up with rads upstairs and UFH downstairs. I have installed the manifold for the UFH along with 2x Honeywell 2port values, one near the manifold and the other on the radiator side. I will be using Nest 3rd gen thermostats to control both the upstairs radiators and...
2K
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised valves simple bi-metal thermostat on wall in flat with 4 standard TRV's rarely used so not worried about the flat, and main house has Nest Gen 3 in the...
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented tank, zone vavles, pump, expansion is on first floor in airing cupboard - Currently piped as S-plan. - Hive controls. - Would like to fit 6-zone...
