Discuss Nest Thermostat firing boiler every hour in the Plumbing Jobs | The Job-board area at PlumbersForums.net
good morning folks,
We moved into a new house about 4 months ago and straight away swapped the old danfloss programmer with a 3rd generation nest thermostat. I am super happy with it and know we are saving a bucket load of oil using it. One quirk of it is that once or maybe twice and hour the boiler will fire up for about 2 minutes and then shut itself off. Is this normal with the nest system? It's not bothering us at all but would like to know it's nothing to worry about.
Oil combi boiler ?
Is it Nest or is it the boiler deciding to fire up?
Can you see Nest calling for the boiler when it's on for these 2 minutes?
Were you in the house, before you fitted Nest, long enough to notice this random firing?
Has the boiler got a Frost stat?
You don't see anything on the nest display when it does fire so I am almost sure it's just the boiler doing this or the nest doing it but not for a call for heat or water. I know it does a cycle to prevent legionaries in the pipes but it does show that on the nest display. We changed the old timer as soon as we got it so can't answer the old performance unfortunately.
I haven't seen a frost stat mentioned in the boiler docs. It has been happening no matter how nice the weather has been though :)
Reply to Nest Thermostat firing boiler every hour in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a home with an oil boiler in a garage turned into a flat, heating both flat and main house, running c plan with two pumps, two motorised valves simple bi-metal thermostat on wall in flat with 4 standard TRV's rarely used so not worried about the flat, and main house has Nest Gen 3 in the...
Hi everyone, Just wanted to share my experience with "upgrading" an S plan setup to Opentherm and Vaillant Control Center (VR66). There are a few threads on a few different forums but I wanted to share a full write-up with all the steps needed, benefits and costs. Overall, I fully recommend...
1K
Hi all, I have an Ideal Logic max 35 and have just connected my Nest thermostat via opentherm. The boiler modulates the water temp fine but as the heat reaches the the target temp on the thermostat, the boiler turns the flame off, keeps the pump running and then every 90-120seconds refires the...
5K
Hi, Over the past few months, my wife and I have noticed a constant pulsing sound throughout the house which is particularly noisy at night (this could be as a result of us noticing the sound more when there is less environmental noise). Unfortunately, it is severely disrupting our sleep, so we...
Hi, I live in Lisbon and I've just installed a Baxi combi boiler and connected it with a Google nest 3rd generation thermostat as the picture below depicts. The issue is that the nest thermostat can't detect the Boiler's OpenTherm connection and displays the following error: Does anyone has...
4K
