Discuss New combination boiler... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Old Account
hi lads
I just seen that Worcester / junkers has a new combination boiler as well as combo with a cylinder.
Top quality boiler I’d say especially when it comes to the controls.
Perhaps one or another is interested in something new. I’m going soon back to Germany and will have the pleasure to install one of these.
Not coming to the uk market
Reply to New combination boiler... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I’m hoping for some perceptive / input as I’m a long-distance landlord trying to unpick the best thing to do. Gas safety certificate was done on my rental flat (1st floor) which has a 10 year old Aviston E-combi EVO boiler. It failed based on rusting external flu components, which has...
I’m replacing my single skin plastic oil tank with a new bunded oil tank. I’m going to replace the single 10mm pvc covered oil pipe too, so to keep the number of compression joints to a minimum, I’d like to fit an external tigerloop combi 3 de-aerator (the one that incorporates an isolation...
I just had a quote for a new boiler install as follows I dont undertand why a 15-60 boiler pump is needed and a 25-100 pump is needed as well I currently have an ideal mexico 2 heat only boiler - It has one DAB pump on the boiler return and a 2 port valve at the flow pipe to allow for heating...
We have an oil delivery booked for Friday but we ran out earlier today. We topped the tank with 150L from containers, bled the first boiler from the Allen key until the oil ran free and it fired up fine. Did the same on the second one but that had an E9 over temp error. We reset the thermostat...
Hi Can you help me determine if my new Navien lcb700 lsx is working as expected? I got the Navien oil boiler installed to replaced an old firebird boiler. The new boiler is a condensing oil boiler and I’m not sure if this is working as expected. I’ve a 300 L water cylinder and after one hour...
2K
