Discuss New Danfoss oil pumps / bypass screw in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Gazzt
Just to warn oil boiler engineers, new danfoss oil pumps come setup for a two pipe system, so you have to remove the bypass screw for single pipe installation. It will save you time cleaning soot out and potentially damaging the new pump.
I must look out for that! Most boilers are still single oil pipe and oil hose
I can't see any logic in doing that as most oil boilers run off a one pipe system as Best has said. Thanks for the heads up though. Good old Danfoss!!
I know its really annoying, i have went to quite a few jobs handymen have fitted a new pump and it left a sooty mess.
Probably to save the cost of the little plastic bag that they
packed the screw in.;)
Is it just the 21's? The 11's you have to remove the horseshoe washer so I'm assuming that is still the case. But will defo bear in mind!
Can you explain further... if I buy a new danfoss oil pump you say it's set up for a two pipe system so I need to remove the bypass screw? Where can I get the instructions so I can further my learning.cheers
Most pumps come with a screw in a little bag that you insert if you need to run it on a two pipe system. This is because you are using two ports on the pump and the internal by pass is not required, so you use the screw to close it off.
I have (as mentioned above) come across one recently with the screw in place. I am pretty sure that was a Danfoss Pump (Odd thing to do in my opinion, I cannot see the logic).
If you run a pump on a one pipe with the screw in place, it can damage the pump.
The pump I bought came with no warning that the screw was inside the pump already.
I hope this is not a wind up but ok I will bite.
The instructions for the pump will be packed in
the box with the pump.
It seems to be in the bfp21, it isn't clear in the instructions, i was warned by my plumbing merchants also about this problem.
Reply to New Danfoss oil pumps / bypass screw in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The existing pump flows downwards. The manual for the proposed replacement recommends that it should pump upwards. This would involve rearranging the flow &...
Central Heating Pump - G Pump Force HE-RS25/6PWM-130 Hi, I would be grateful if someone could explain whether our CH system can cope with the AUTO (adaptive mode) setting on this the new pump or which mode it is best set at (recently had our old 3-speed pump replaced with the above smart...
I’m replacing my single skin plastic oil tank with a new bunded oil tank. I’m going to replace the single 10mm pvc covered oil pipe too, so to keep the number of compression joints to a minimum, I’d like to fit an external tigerloop combi 3 de-aerator (the one that incorporates an isolation...
Hi, I have just had my central heating system "upgraded" for a four bed-roomed detached house. The heating company recommended going from the open vented system to sealed / pressurized system, new pump ( UPS3 Grundfos ) all new plastic pipework ( extending ) the 22mm feed and return pipes so no...
1K
I'm looking for some advice on a frustrating problem I'm having with my old Eurostar 50-60s oil boiler please? Although it's old, most parts needed to operate it are now new. The symptoms indicated a broken/seized burner motor or oil pump. I wrongly assumed the motor so I ordered a new one only...
