Discuss new gas run in the Plumbing Jobs | The Job-board area at PlumbersForums.net
SafeGasInstall
Subscribed
today did a new gas run ,customer asked to reconnect existing gas appliances i refused to do it as !gas hob did not have isolating valve ,sign of burn on taps ,primary air port partly block with sh''''t ignition button missing!so ID i thought
boiler flue less then 300 mm from internal corner-ncs
and boiler flue less then 300 mm from openable window ncs
so two ncs i thought is AR
finished gas run all sound left property with second ECV-OFF in the kitchen with end feed cup .caped the meter till appliances are sorted!and did not connect them !
no one live in as house flooded as main burst ,they digged it out and damaged gas pipe as all pipe work was concrete up and not protected at all .
did i do the right thing?
iso valve >ncs burnt taps >id combustion issues >id ignition button >wear and tear at a pinch ar(if electric)
BOILER 300mm from internal corner>depends on mi,s baxi 105 he (example)25mm,openeble window 300mm so again mi sacrosanct
I would have brought the items mentioned up. with who ever was responsible before I ran the new gas supply. leaving yourself open to un-necessary problems
but hope all works out Ok
How would you classified it as less then 300 to internal corner
Less then 300 to window!
And what is wiring me boiler has been service before and they did not picked it up!
Am I wrong?
You are not wrong but you should have pointed out the problems before you started. It would have saved a lot of hastle.
Oh yes I did,just wanted to see what you guys think!
First think I did was visual on the appliances and explain to customer about there options !
Plus insurance work did nor cover reconecting appliances !
Think I will go back to put new gas hob and posible plum kit ,or if they want new condensing boiler!
Spot on with the cooker with signs of scorching etc. The boiler is a bit more of a grey area.
How old is the installation? How far off is the flue as per MI's? Is there any evidence combustion etc. was effected previously?
It is at your discretion to conclude wither multiple fluing NCS's are serious enough to elevate to AR or even ID. Two minor flue NCS's do not automatically mean AR.
If for example the MI's state 300mm from opening window and corner and the flue is only 280mm, there is no signs of combustion gasses entering the window and appliance is operating correctly then it would still be NCS. If flue was 150mm form window then it would be AR unless signs of POC's in property, then ID.
Reply to new gas run in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all. I'm new to this forum and need some advice about some concerns about a new gas boiler that I have had fitted by a gas safe engineer. My old boiler was a heat only (with a copper tank) and has been replaced by a modern combi boiler. It just used two 22mm pipes to feed to the diverter...
4K
I need some advice… Our gas meter is currently in the garage conversion and runs under the stairs into the kitchen where we have the boiler. We want to do the following things: 1. Replace with a combi boiler and move to the loft. We are a semi detached house so need to the pipes run up from the...
2K
A number of issues have been raised from a boiler replacement. Boiler not operating and with no pressure. Tile damage Sprawling pipe layout in kitchen (Retrospective view of alternate option when it was found that promise of removing pipes from airing cupboard could not be fulfilled). Battery...
5K
  • Locked
Hi, I am currently having a few quotes done to replace my boiler+cylinder with a combi and one of the plumber who offered to fit either atag or a vieassmann said that I can't have a boiler that supply 30kw because my connection for the gas supply is provided through a 22mm pipe. He told me...
4K
Dotty
  • Locked
I have learned a lot reading the forum and thought I should contribute back with my recent experience.I bought a 90 square meter 2 story row house with a 22kw gas Vaillant non-combi boiler in the loft that is approximately 12 years old. The water was heated with electric point-of-use heaters in...
2K
